[phpBB Debug] PHP Warning: in file /includes/functions.php on line 4559: Invalid argument supplied for foreach()
Dampfradioforum • Thema anzeigen - grundig 1070
Aktuelle Zeit: Do Apr 25, 2024 8:26
Ein neues Thema erstellen Auf das Thema antworten  [ 4 Beiträge ]
 Betreff des Beitrags: grundig 1070
BeitragVerfasst: Fr Jul 12, 2019 18:23
Hi, before I have written that board, I buyed a grundig K2 console and it has 1070 chassis but the radio is not working and there is a burn resistör(R38 1.3K ).when I plug comes smoke.I reinstall elektrolitic capacitors (47uf 400V).I want to send a picture but I couldn't send.
 Profil
Mit Zitat antworten
 Betreff des Beitrags: Re: grundig 1070
BeitragVerfasst: Fr Jul 12, 2019 19:25
Hello,
you probably have to resize your image(s) due to the size limitation. The maximum allowed size for attachments is 180kB. You can use Paint or IrfanView for example to resize your image(s).
If you have to German Version of the Grundig K2 or Musikgerät 1070, then you can find a fitting schematic here: https://nvhrbiblio.nl/schema/Grundig_1070.pdf
In the schematic you can see that the resistor R38 is connected in series to a 50µF capacitor, which is probably the big cylindrical capacitor mounted on the chassis. In most cases, this part contains two capacitors in one housing, but you can replace this part with two individual capacitors with the same ratings.
Maybe the capacitor is faulty and you need to replace it. Before you turn on the unit, you should check if R38 is still 1,3kOhms.
If that doesn't solve the problem, you should check R37, R31 and R14 and the circuit which comes after them. R38 ist also connected to the EL84, but I'm not sure if the EL84 can cause such a problem. Maybe a more experienced person can answer that question.
Best Regards
 Profil
Mit Zitat antworten
BeitragVerfasst: Fr Jul 12, 2019 22:34
Grundig_1070-shorting.png [ 22.5 KiB | 2639-mal betrachtet ]
Hello inecik
In 90% is "marked" C 4700pF shortet in this case.
johann
 Profil
Mit Zitat antworten
BeitragVerfasst: Sa Jul 13, 2019 19:08
Radiowerkstatt hat geschrieben:
Hello inecik
johann
thanks johann, I have replaced 4700pf cap. and the radio is working now.
 Profil
Mit Zitat antworten
Beiträge der letzten Zeit anzeigen:  Sortiere nach
Mitglieder in diesem Forum: Erling und 1 Gast
Suche nach:
