Hi Klarzeichner and everyone else
yes the zeilentrafos fail often on this sets but i have one replacement for now if one fails
their reliability like saba78 says comes from the fact that they use quality capacitors on them, for example i have a nordmende set and almost all the capacitors were leaky (wima brown capacitors)so it was hard and expensive to repair
i dont like the fact that these tvs have both transistors and tubes, makes the troubleshooting more complex
but they sure have a very nice picture and the philips crts seem to last for very long
so this set is all polished and cleaned and is on the shelf ready to use
WP_20181126_00_16_01_Pro.jpg [ 156.94 KiB | 11274-mal betrachtet ]
today i started working on one of the other sets wich has a LOT of hours and is completely dirty with cigarrete crap
WP_20181126_00_02_58_Pro.jpg [ 166.45 KiB | 11274-mal betrachtet ]
i got to a point where everything is working fine but i cannot get the vertical to lock
the picture either rolls up or rolls down as i turn the vertical stabilization potentiometer, i can make it roll fast or slow but not lock
so i started testing around the sync separator and the sync pulses for the vertical are present
i replaced a bunch of suspect capacitors around the vertical output and i replaced the vertical output tube
i took some readings with the oscilloscope and the vertical drive waveform is present and looking good but it seems to have low amplitude
from the oscillator to the output section the waveform looks inverted and weird, i included a picture showing it to you (i drawed it in blue)
the waverform frequency changes if i rotate the vertical hold (stabilization) control
i spent the entire afternoon testing and cannot find the problem
the components i highlighted in green were changed, the transistor was changed with an AC125(less current rating) temporarily but as it did not fix the problem i put back the original AC132
please german tv experts give me a help
Sem Título.png [ 157.8 KiB | 11274-mal betrachtet ]
BTW i am using the schematic suggested by saba78 wich seems to match this tv almost perfectly atleast on the vertical circuits so thank you a lot
the appropriate schematic is not available anywhere
