Hi I have a ITT pinto radio, just now,my radio is working very well but I have a question,
I adjust the radio station but When I move away from the radio , the tuning is distorted.
Itt pinto radio
inecik
inecik
Re: Itt pinto radio
Hi, is there anyone !!!!
Der Hesse
Re: Itt pinto radio
Hei there,
du you have an antenna conectet? If not then you are the antenna
Or is this radio a portable? Then it is possible that you must adjust the direction of the antenna.
Gruß Der Hesse
der mit der Hexe tanzt
(Piaggio Hexagon180)
berndw
Re: Itt pinto radio
Hi Mr. Unknown / Mr. Impatient,
can we assume this the radio you are talking about? https://www.radiomuseum.org/r/itt_pinto.html
If yes, then tell us:
- is the problem on FM or AM?
- is the FM antenna at full length?
- have you checked the connection between PCB and FM (telescopic) antenna?
Best regards, Bernd
Best regards, Bernd
Schöne Grüße, Bernd
inecik
Re: Itt pinto radio
Hi, this radio is a portable radio and have 70cm antenna and my problem is on fm.the antenna connection is okey.
Der Hesse
Re: Itt pinto radio
did you find the problem?
Gruß Der Hesse
