best klang röhrenradio
inecik
Beitrag von inecik »
Hi, I am from Turkey, and I am restorating tube radios, off course hobby.I enjoyed germany radios, I want to learn that; best sound germany radios and I have looked about this informations on some forum, for example ;philips capella, sinfonia, saba frieberg VIII,graetz sinfonia etc. but that radios are very big( 65-70cm).can you recomment another smaller radios, but best sound. regards
mnby101
Re: best klang röhrenradio
Beitrag von mnby101 »
Hi, I think it would be a good idea to tell us your name, its easier for all to call you. Anyway, its not easy to say which radio has the better sound, Grundig, Philips or what else. In general you can say the sound will be more powerful if the cabinet of the radio is bigger and its made from wood. Also if more loudspeakers are in use, that is most the case in bigger cabinets. A push-pull amplifier makes a stronger bass as well (more power). I think you will not find a small radio with a big bass, a good sound will be possible but without a strong bass. So you have to compromise what is more important for you, the strong bass or the small cabinet.
Greetings.
Grüße aus Ingelheim am Rhein,
Norbert (DF8PI)
That's all correct, but from my point of view, there is no radio with the absolute best sound.
It is a matter of opinion which sound is considered as "good" or not. For example, one listener likes a strong bass, whereas another one doesn't. One listener is especially sensitive to buzzing and other noises, another one to non-linear distortions, to frequency response or phase errors, and so on.
Last but not least, it depends on the style of music, on the recording technology/quality and sometimes even on the sound storage medium or the transmission path. For example, many radio stations falsify the frequency response in order to get a powerful sound, but that doen't sound good on every radio.
Therefore, everyone has to find out individually which sound he likes most.
inecik
you are right,another questions; can you recomment best sensitive ( for ukw because on my area there are only ukw stations) radio, may be middle dimentitions.I can buy a radio on ebay de.
tgrassner
Beitrag von tgrassner »
Hi!
Choose a radio built roundabout 1953 to 1960. Earlier radios have weak fm tuners.
Grüsse aus dem Münsterland
Thorsten
yehti
Beitrag von yehti »
Moin!
Warning: Technobabble!
Try to get a Radio with 2 EF89 Tubes in the IF circuit, like a Graetz Sinfonia 422.
They are more sensitive as the ones with only one Tube.
Regards, Gerrit
Don't forget that the alignment has great effect on sensivity.
A radio with two EF89s, but poor RF and IF alignment, may be less sensitive than another radio with only one EF89, but optimally adjusted.
For best reception and sound, it is not sufficient to choose the best equipment. It is just as important that the equipment is in good condition.
