Hello,
does anyone have a code list with corresponding values of dial lamps which were mounted in Philips radios?
I'm restoring a Philips BX998A, and there are four different types of lamps with coding:
8089N-38
7994N-38
7994N-00
8024N-07
What standard values would those be?
Regards
Piotr
Philips dial lamps coding
PJ.
Mathias
Re: Philips dial lamps coding
Hallo Piotr,
I think here you can find the usual tube designations .
http://frank.pocnet.net/other/Philips/P ... ListAB.pdf
Sorry, I have understood the question completely wrong .
Thank you Joerg.
Beste Bastlergrüße, Mathias
Thank you Joerg.
Zuletzt geändert von Mathias am So Okt 04, 2015 9:48, insgesamt 1-mal geändert.
Binser
Dear Piotr,
The "8089" ist 12V/100mA, "N" stands for bajonet socket, "38" indicates that the top of the bulb is slightly painted to prevent blinding.
"7994" is 7,2V/100mA, "N" and "38" as written before, "00" indicates transparent glas.
"8042" is 6,3V/300mA, "N" as written before, "07" indicates ground glas (Mattglas).
Kind regards,
Joerg
Kind regards,
Joerg
www.radiolegenden.de
PJ.
Thank you for your answer, that's what I was looking for. They are actually painted(white and black), few of them from one side, on the others only their top is clear.
Regards
Piotr
Regards
Piotr
