Grundig 4040W/3D - loudspeaker
PJ.
Beitrag von PJ. »
Hello,
I have chance of buying Grundig 4040W 3D, but the main problem is that the radio is missing its front oval loudspeaker.
Does anyone know, if similar loudspeaker was used in some other not so top-of-the-line models? There are many Grundig radios on sale - they usually go cheap as they're so similar. I would then take loudspeaker from some other model.
Regards
Piotr
Elko
Re: Grundig 4040W/3D - loudspeaker
Beitrag von Elko »
Hallo Piotr!
On this site
http://www.radiomuseum.org/
you can look which loudspeakers are installed in the different Grundig models.
You simply give the model - then you get the pictures.
Greetings to Poland
Zuletzt geändert von Elko am Sa Dez 19, 2015 13:46, insgesamt 1-mal geändert.
noli turbare circulos meos
Mit Röhrengruß
I hope these loudspeakers are fitted, or installed, rather than obstructed... :wink:
Elko
Beitrag von Elko »
Hallo Lutz!
Wie ich sehe, konnte ich Dir heute schon ein wenig Freude bereiten.
Sch.......ß Übersetzungsprogramm.
So einfach geht es, jemand zu erheitern. :lol:
Mit Röhrengruß
PJ.
Beitrag von PJ. »
That's OK friends, no need to nitpick :)
As it turned out, I no longer have a problem, someone overbid me at the last seconds. I was so sure of winning that I set a price which was slightly too low.
So the topic is no longer needed, mods can delete it if they want :)
Regards
Piotr
Beitrag von BugleBoy »
good, no problem exits :-D
regards to poland
matt
