Schaub Lorenz Goldsuper W42
panagiotis
Beitrag von panagiotis »
FM tuner messed up badly.No reception at all.
Where can i find a replacement Gentlemen?
SABA78
Re: Schaub Lorenz Goldsuper W42
Beitrag von SABA78 »
Hello,
did you check the adjusteable ceramic capacitors ? They often loose their capacity caused by oxydation of the silver-surface. Sometimes turning them a bit helps. Sometimes their just dead and have to be replaced. It's a common problem at some Siemens-Radios of the 50s when the FM-Band is dead or weak.
Good luck!
Daniel
panagiotis
Thanks Daniel! but is messed up so bad.All screws are turned,Even the black screws in the plastic.
I guess is not fixable,and if it is i'm not that expert!
I could change the whole FM aluminium box i guess if i find one)
Panagiotis, please show us the complete fm box with upper cover. I have some 60 fm boxes on stock, so perhaps....
Best wishes
panagiotis
Thanks Holger!
Panagiotis, I have exactly, what you are looking for:
I have butchered a Goldsuper last year. Go ahead with PN please.....
panagiotis
You have a PM Holger!
