phona connection
inecik
phona connection
Beitrag von inecik »
Hi, I have a plattenspieler and I want to connect to tube radio.pickup output have two wire. is there different ( positive or negative wire), or can I connect any wire to anywhere.
radioschrat
Re: phona connection
Beitrag von radioschrat »
One of the two should be ground and needs to be connected to the ground (usually the lower) terminal of the phono input. Just try it out. You'll most probably get a strong mains hum if you got it wrong but you can't break anything.
