hi,I have a new replica dial skala, I will try to tell you that how make
1-I have got a new orjinal skala( on another same model radio)
2-I have a clear copy from  this skala on copy center it is 1 euro
3-I have got  3mm glass same measurements
4-I have glued clear copy on glass(the copy is self-adhesive)
5-I have glued masking tape on clear areas
6-I have painted gold paint back cover of skala
7-I have removed masking tapes
						making a new dial skala
				inecik
				Radio Alex
Re: making a new dial skala
Hell0,
Very interesting, I am planning to do something similar.
How did the end result come by? Did you glue the foil on the top or bottom?
Schöne Grüsse,
Alex
						Alex
				inecik
I glued the folyo back of glass,the copy is reverse because I must glue back of glass.
				Radio Alex
Hello
It looks very good
Have do any modifications on the scan and when yes what is the name of the program?
And also interesting would be the scanner setting.
Best regards
							It looks very good
 .  Have do any modifications on the scan and when yes what is the name of the program?
Best regards
Schöne Grüsse,
Alex
						Alex
